How Do I Check My API Usage?
To help you stay informed about your account activity and manage your usage effectively, we’ve put together a quick guide on how to check your API usage. Please note, data per account is updated every 10 minutes.
_____________________________________________________________________________________________________________________________
Please note: the following article only pertains to the product/subscription(s) listed below.
Aero API
Step 1: Log In to Your Account
Step 2: Navigate to Your AeroAPI
There are two ways to navigate to the AeroAPI Management Page :
  1. Direct Link
  2. From the Guide Bar
    • After logging in, click on My AeroAPI from the navigation bar.
Step 3: API Usage
  • Once you enter the My AeroAPI area of your FlightAware account, you will be presented with your AeroAPI Portal. To check your usage, select the API Usage tab. When active, the line graph will indicate which calls have been made and the quantity. Please note, current usage and cost information is updated every 10 minutes (not real-time), and does not reflect monthly minimums when they are applicable.Screenshot 2025-06-03 at 8.21.32 AM.png
  • Another option to pull this information at zero cost through an AeroAPI endpoint is the GET /account/usage endpoint. Documentation on how to use this endpoint can be found here: https://www.flightaware.com/aeroapi/portal/documentation#get-/account/usage
 If you still need assistance, please reach out to support@flightaware.com with your request.
Was this article helpful?
0 out of 0 found this helpful
Have more questions? Submit a request
